Re: How to Fix Your Moped
Jon Dalton /
It is probably the clutch. It jerks forward right? I would try unscrewing the idle screw until you can hold the rear wheel without much force to see if the engine can't run that slow. It could be that the engine won't idle that low because of a dirty carb or bad ignition points or spark plug. You could also try gradually putting on the back brake and see how low the engine will run and if the clutch eventually slips or just stalls out.
  How to Fix Your MopedTopic by: Fred Fred 04/30/01 04:04PM
  Re: How to Fix Your MopedRe: JT JT 04/30/01 04:19PM
  Re: How to Fix Your MopedRe: Dan Dan 04/30/01 06:22PM
  Re: How to Fix Your MopedRe: Jon Dalton Jon Dalton 05/01/01 12:01AM
  Re: How to Fix Your MopedRe: Doug D. Doug D. 05/01/01 01:23AM
  Re: How to Fix Your MopedRe: Fred Fred 05/01/01 02:49PM
  Re: How to Fix Your MopedRe: Simon King Simon King 05/01/01 04:34PM
  Re: How to Fix Your MopedRe: Brodskey Dudsie...seriously Brodskey Dudsie...seriously 05/02/01 07:33PM
  Re: How to Fix Your MopedRe: Fred Fred 05/04/01 12:40AM
  Re: How to Fix Your MopedRe: Magic T. Magic T. 06/18/01 01:02AM
