Re: Peugeot carb. probs
Reeperette /
In order for the fuel to come out, air has to go in...so if no air is coming in (cause the carb is hooked up) something must be clogged or plugged.
You could try priming the carb manually and starting her up, but if something's clogged you won't run very long on the little bit in the carb.
Hit up this post ( https://www.mopedarmy.com/forums/discuss/1/8221/8221/ ) and read through the carb-cleaning part, especially about using compressed air, cause that's likely where any not-so-obvious clog would be.
Hope that helps,
-Ree
  Peugeot carb. probsTopic by: Matt Matt 04/30/01 10:50AM
  Re: Peugeot carb. probsRe: Reeperette Reeperette 04/30/01 11:40AM
  Re: Peugeot carb. probsRe: Ron Brown Ron Brown 04/30/01 12:53PM
  Re: Peugeot carb. probsRe: Michael Michael 04/30/01 07:48PM
