Re: Derbi Variant Revolution crew checkin
mattology - /
polini makes a performance variator. my stock variator is slowly wearing out, the ramp plate steel backing plate thing is about done for..
241.570 VARIATOR DERBI HUNTER-CAGIVA
I'm 99% sure that this variator fits the revolution. But since I haven't ordered it yet I can't verify it.
I'm using a tomos wheel so i have options from 48T - 20T for the rear. italian sprockets + tomos sprockets = insane gearing options.
The tomos streetmate wheel goes right on and spaces perfectly. brake plate / chain / all of it.
13/33 gives me 51mph, 13/22 goes almost 70. It should do 75 on paper, and i've about near maxed it out at that speed going over the bridge, but I don't have a gps. all i know is that it's way faster than i've ever gone, even on my aprilia RS50.
22 / 24 / 26 / 28 / 31 / 32 / 33 / 36 / 40 are all available for me now for out back. Up front I have 13 and 17 right now for options. So if i were to go racing, i'm pretty sure i could have a gearing solution.
I believe it uses a derbi senda front sprocket, that's what dan says as far as i know.
It also uses a similar to a honda DIO clutch. so you can get a polini clutch for it.
249.049 CLUTCH PIAGGIO 50 3 SHOES F.RACE
I'm pretty sure this clutch will fit the revolution. But again... i haven't tried it myself, i've just cross referenced Start 5 part numbers with regular numbers.
the stock variator uses 17x12 and i've experimented a bunch with weight. I have had good luck using about 20g of weight in mine i believe.
  Derbi Variant Revolution crew checkinTopic by: mattology - mattology - 03/24/10 12:19PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/24/10 12:21PM
  Re: Derbi Variant Revolution crew checkinRe: Mo Peds Mo Peds 03/24/10 12:22PM
  Re: Derbi Variant Revolution crew checkinRe: Mo Peds Mo Peds 03/24/10 12:30PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/24/10 12:45PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/24/10 01:12PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/24/10 01:15PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/24/10 01:22PM
  Re: Derbi Variant Revolution crew checkinRe: Sadder Joey P Sadder Joey P 03/24/10 03:07PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/24/10 03:31PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/24/10 03:42PM
  Re: Derbi Variant Revolution crew checkinRe: Chris R Chris R 03/24/10 03:59PM
  Re: Derbi Variant Revolution crew checkinRe: Mo Peds Mo Peds 03/24/10 09:06PM
  Re: Derbi Variant Revolution crew checkinRe: Not Tate Not Tate 03/24/10 11:13PM
  Re: Derbi Variant Revolution crew checkinRe: Pablo Puchasso Pablo Puchasso 03/25/10 05:25AM
  Re: Derbi Variant Revolution crew checkinRe: Dan O Dan O 03/25/10 05:37PM
  Re: Derbi Variant Revolution crew checkinRe: Dan O Dan O 03/25/10 05:41PM
  Re: Derbi Variant Revolution crew checkinRe: Jesse -B Jesse -B 03/25/10 05:44PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/25/10 05:59PM
  Re: Derbi Variant Revolution crew checkinRe: Dan O Dan O 03/25/10 06:46PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/25/10 07:18PM
  Re: Derbi Variant Revolution crew checkinRe: Not Tate Not Tate 03/25/10 07:41PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/25/10 07:59PM
  Re: Derbi Variant Revolution crew checkinRe: Dan O Dan O 03/25/10 09:00PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/25/10 10:01PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/25/10 11:28PM
  Re: Derbi Variant Revolution crew checkinRe: Not Tate Not Tate 03/25/10 11:45PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 12:01AM
  Re: Derbi Variant Revolution crew checkinRe: Mo Peds Mo Peds 03/26/10 12:15AM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 12:20AM
  Re: Derbi Variant Revolution crew checkinRe: Mo Peds Mo Peds 03/26/10 12:21AM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 12:29AM
  Re: Derbi Variant Revolution crew checkinRe: ) CuperAWESOMO ( ) CuperAWESOMO ( 03/26/10 12:39AM
  Re: Derbi Variant Revolution crew checkinRe: justin turner justin turner 03/26/10 12:39AM
  Re: Derbi Variant Revolution crew checkinRe: boobby boobby 03/26/10 01:54AM
  Re: Derbi Variant Revolution crew checkinRe: Nash . Nash . 03/26/10 02:13AM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 02:16AM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 02:29PM
  Re: Derbi Variant Revolution crew checkinRe: Tate Tate 03/26/10 02:55PM
  Re: Derbi Variant Revolution crew checkinRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 03/26/10 03:02PM
  Re: Derbi Variant Revolution crew checkinRe: Born to be WillD Born to be WillD 03/26/10 07:00PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/26/10 07:04PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 07:21PM
  Re: Derbi Variant Revolution crew checkinRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 03/26/10 08:38PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 08:57PM
  Re: Derbi Variant Revolution crew checkinRe: Not Tate Not Tate 03/26/10 10:02PM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/26/10 10:36PM
  Re: Derbi Variant Revolution crew checkinRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/27/10 01:04AM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/27/10 02:18AM
  Re: Derbi Variant Revolution crew checkinRe: Kelin Kelin 03/27/10 04:31AM
  Re: Derbi Variant Revolution crew checkinRe: mattology - mattology - 03/27/10 11:54AM
  Re: Derbi Variant Revolution crew checkinRe: Kelin Kelin 03/27/10 03:55PM
  Re: Derbi Variant Revolution crew checkinRe: Tate Tate 03/27/10 09:00PM
  Re: Derbi Variant Revolution crew checkinRe: boobby boobby 03/27/10 10:19PM
  Re: Derbi Variant Revolution crew checkinRe: Dan O Dan O 03/27/10 11:29PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 10/14/16 11:12AM
  Re: Derbi Variant Revolution crew checkinRe: Bas Autowas Bas Autowas 10/14/16 03:11PM
  Re: Derbi Variant Revolution crew checkinRe: ◕ ‿ ◕ ◕ ‿ ◕ 10/14/16 11:23AM
  Re: Derbi Variant Revolution crew checkinRe: Kyle M. Kyle M. 10/14/16 01:35PM
  Re: Derbi Variant Revolution crew checkinRe: Ryan N. Ryan N. 10/14/16 01:47PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 10/14/16 02:55PM
  Re: Derbi Variant Revolution crew checkinRe: Dave & Bummerzz Dave & Bummerzz 10/14/16 03:28PM
  Re: Derbi Variant Revolution crew checkinRe: Kyle M. Kyle M. 10/14/16 10:35PM
  Re: Derbi Variant Revolution crew checkinRe: LSLB RXb LSLB RXb 10/15/16 12:18AM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 10/28/16 12:17PM
  Re: Derbi Variant Revolution crew checkinRe: ◕ ‿ ◕ ◕ ‿ ◕ 10/28/16 04:33PM
  Re: Derbi Variant Revolution crew checkinRe: GFB CME GFB CME 11/01/16 04:15PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/01/16 04:17PM
  Re: Derbi Variant Revolution crew checkinRe: GFB CME GFB CME 11/01/16 04:23PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/01/16 04:59PM
  Re: Derbi Variant Revolution crew checkinRe: Richard Schwartz Richard Schwartz 11/04/16 12:54PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/04/16 01:18PM
  Re: Derbi Variant Revolution crew checkinRe: T y l e r T y l e r 11/09/16 03:02PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/09/16 06:01PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/11/16 11:38PM
  Re: Derbi Variant Revolution crew checkinRe: Yves Xerse Yves Xerse 11/04/16 03:58PM
  Re: Derbi Variant Revolution crew checkinRe: Benjamin LaPlante Benjamin LaPlante 11/08/16 06:59PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/08/16 07:01PM
  Re: Derbi Variant Revolution crew checkinRe: Benjamin LaPlante Benjamin LaPlante 11/08/16 08:03PM
  Re: Derbi Variant Revolution crew checkinRe: Ryan N. Ryan N. 11/09/16 09:23AM
  Re: Derbi Variant Revolution crew checkinRe: Benjamin LaPlante Benjamin LaPlante 11/09/16 09:34AM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/09/16 09:34AM
  Re: Derbi Variant Revolution crew checkinRe: ◕ ‿ ◕ ◕ ‿ ◕ 11/09/16 11:19AM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 11/09/16 11:26AM
  Re: Derbi Variant Revolution crew checkinRe: ◕ ‿ ◕ ◕ ‿ ◕ 11/09/16 11:56AM
  Re: Derbi Variant Revolution crew checkinRe: Russell Huddy Russell Huddy 11/09/16 12:16PM
  Re: Derbi Variant Revolution crew checkinRe: ◕ ‿ ◕ ◕ ‿ ◕ 11/09/16 01:52PM
  Re: Derbi Variant Revolution crew checkinRe: Ryan N. Ryan N. 11/09/16 02:34PM
  Re: Derbi Variant Revolution crew checkinRe: Russell Huddy Russell Huddy 11/09/16 02:43PM
  Re: Derbi Variant Revolution crew checkinRe: GFB CME GFB CME 11/15/16 04:46PM
  Re: Derbi Variant Revolution crew checkinRe: Russell Huddy Russell Huddy 11/15/16 04:54PM
  Re: Derbi Variant Revolution crew checkinRe: T y l e r T y l e r 11/16/16 05:28PM
  Re: Derbi Variant Revolution crew checkinRe: Thomas TPRF Thomas TPRF 11/28/16 05:59PM
  Re: Derbi Variant Revolution crew checkinRe: Dan O Dan O 11/20/16 07:32PM
  Re: Derbi Variant Revolution crew checkinRe: Kyle M. Kyle M. 11/20/16 10:35PM
  Re: Derbi Variant Revolution crew checkinRe: Thomas TPRF Thomas TPRF 11/28/16 06:11PM
  Re: Derbi Variant Revolution crew checkinRe: T y l e r T y l e r 11/28/16 06:31PM
  Re: Derbi Variant Revolution crew checkinRe: Thomas TPRF Thomas TPRF 11/29/16 09:58AM
  Re: Derbi Variant Revolution crew checkinRe: T y l e r T y l e r 11/29/16 05:36PM
  Re: Derbi Variant Revolution crew checkinRe: Thomas TPRF Thomas TPRF 11/29/16 08:35PM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 12/06/16 11:17AM
  Re: Derbi Variant Revolution crew checkinRe: Thomas TPRF Thomas TPRF 12/06/16 11:29AM
  Re: Derbi Variant Revolution crew checkinRe: Dave & Bummerzz Dave & Bummerzz 12/06/16 11:37AM
  Re: Derbi Variant Revolution crew checkinRe: Jake P Jake P 12/06/16 11:49AM
  Re: Derbi Variant Revolution crew checkinRe: Rob Rob Rob Rob 12/09/16 10:03PM
