Re: Derbi Variant Revolution crew checkin
This is the only pic ive got of mine, engine has been tuned a bit, still waiting for a good WC cylinder to pop up.
Jake P Wrote:
> What gearing do you guys run with a kit?
16x30
17x33
14x30 on a track bike
Anyone able to verify crank bearing and seal size?
start v's are gr8 :)
Any of you guys know what all the wires on the 4-wire CDI do?
HELP!
https://www.mopedarmy.com/forums/read.php?6,4042355
My bet is ground blue
I was wondering that same thing. my stock ignition came with 3 wires
Blue seems to be ground. White/red is headlight, white/yellow is tail light.
weird. why not one wire for both lights? glad you figured it out though.
Not sure. They might be designed to go in to a regulator/rectifier and then be combined to produce 12V DC?
I have one that had turn signals and the wiring is a real mess. I am going to replace the entire harness and simplify someday..
Turn signals would be rad!
Unapproved Message (moderated by simon)
Help i looking for a hold Honda 1975 .. :D
Benjamin LaPlante /
Hey all, just picked up a start v motor that's getting rebuilt. I got a dumb question. Why does it have starter springs behind the clutch? I ask this because the kick starter turns over the crankshaft directly.
You can push start it if you can get it going fast enough.
Benjamin LaPlante /
> enough.
Thank you!
I was never able to push start mine ever. You seriously would have to be going 30mph to get the starter clutch to engage.
Benjamin LaPlante /
So do you guys remove them all together?
I removed mine.
I have a rear pulley that actually doesn't have the bell portion for the starter. I swapped over for a race clutch and didn't notice, so my starter clutch exploded all over my shed.
Basically what I'm saying is I ended removing mine too.
Tommy, which clutch/pulley are you running?
It's an oversized rear pulley, no idea what it's from, and the malossi tuneable clutch from treats
Russell Huddy /
Oversized rear pulley is probably from a Derbi manhattan/hunter scooter. Did you get it from max in Iowa?
nope dos cycles rare secret found in a pile inventory
@ Russell, that motor is here in New Orleans on Eric from MONO's Start5
Russell Huddy /
Glad that clutch is being used,it came off a wrecked scooter I parted out.
I still have the six roller variator and the cdi if anyone wants to trade for flatreed stuff
Did the larger rear pulley so I can run a wider belt.
Tyler, do you know what pulley that is off of? did you have to do anything to adapt it?
Anyone have a video of their Revo acceleration with a metrakit?
I need the cdi if you still have it.
