Re: sparking at the points
Doug D. /
Hi, you have probably allready checked, but if you may have too much voltage, I would ck this again and make sure your grounds are good. Happened to me on a car. Turning points blue, Voltage regulator was bad. I would go back and recheck charging system and battery if so equipted. Doug D.
  sparking at the pointsTopic by: Jon Dalton Jon Dalton 04/26/01 08:10PM
  Re: sparking at the pointsRe: Chris Robertson Chris Robertson 04/26/01 09:25PM
  Re: sparking at the pointsRe: mike mike 04/26/01 09:44PM
  Re: sparking at the pointsRe: Chris Robertson Chris Robertson 04/26/01 09:53PM
  Re: sparking at the pointsRe: Jon Dalton Jon Dalton 04/26/01 10:44PM
  Re: sparking at the pointsRe: Doug D. Doug D. 04/27/01 12:22AM
  Re: sparking at the pointsRe: Jon Dalton Jon Dalton 04/27/01 03:46PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 09:58AM
  pointing at the sparksRe: Fred Fred 04/27/01 02:39PM
  Re: pointing at the sparksRe: Jon Dalton Jon Dalton 04/27/01 03:13PM
  Re: sparking at the pointsRe: Rob Hoehn Rob Hoehn 04/27/01 04:48PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 07:24PM
  Re: sparking at the pointsRe: jimmiegimme jimmiegimme 04/27/01 07:38PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 07:44PM
  Re: sparking at the pointsRe: jimmiegimme jimmiegimme 04/27/01 07:57PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 08:01PM
  Re: sparking at the pointsRe: henry henry 05/17/01 01:52PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 05/17/01 02:19PM
