Re: sparking at the points
Chris Robertson /
Hi:
First, you must have an OEM condenser. I'll assume this is the case.
A little (tiny) bit of arcing across the points is normal, but if it's as bad as you say (where you're points are getting trashed), you're condenser is not hooked up properly OR the wires that it is connected to are faulty.
You can't mix and match condensers because if the value is too small, they won't prevent arcing, and if the value is too large, you won't get a spark at the plug.
Consult <a href="http://www.avweb.com/articles/magcheck/">this document</a> under the section titled "The Capacitor" for information about condensers.
Hopefully somebody knows the capacitance of the PC50's condenser.
I guess if you're desperate, you can start with a very high capacitance condenser (too large to let your engine run), and slowly substitute lower and lower capacitance values until your engine will run properly. NOTE: I have never tried this, and I can only hypothesize that this scheme might work. Use this idea only as a last resort.
Chris.
  sparking at the pointsTopic by: Jon Dalton Jon Dalton 04/26/01 08:10PM
  Re: sparking at the pointsRe: Chris Robertson Chris Robertson 04/26/01 09:25PM
  Re: sparking at the pointsRe: mike mike 04/26/01 09:44PM
  Re: sparking at the pointsRe: Chris Robertson Chris Robertson 04/26/01 09:53PM
  Re: sparking at the pointsRe: Jon Dalton Jon Dalton 04/26/01 10:44PM
  Re: sparking at the pointsRe: Doug D. Doug D. 04/27/01 12:22AM
  Re: sparking at the pointsRe: Jon Dalton Jon Dalton 04/27/01 03:46PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 09:58AM
  pointing at the sparksRe: Fred Fred 04/27/01 02:39PM
  Re: pointing at the sparksRe: Jon Dalton Jon Dalton 04/27/01 03:13PM
  Re: sparking at the pointsRe: Rob Hoehn Rob Hoehn 04/27/01 04:48PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 07:24PM
  Re: sparking at the pointsRe: jimmiegimme jimmiegimme 04/27/01 07:38PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 07:44PM
  Re: sparking at the pointsRe: jimmiegimme jimmiegimme 04/27/01 07:57PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 08:01PM
  Re: sparking at the pointsRe: henry henry 05/17/01 01:52PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 05/17/01 02:19PM
