sparking at the points
Jon Dalton /
this is bad isn't it?? that's what a condenser is for, to stop it from sparking at the points and ruining them. well i got a brand new condenser all wired up fine and it still does it. The points eventually get bad and the engine loses idle, i have to pedal start it at every stop sign, and it eventually quits altogether. then i file and sand the points real good, engine works fine, for a while, then same thing all over again. I jsut got my new points from the dealer, put them in and it's the same. only a matter of time before they're garbage too. how do you stop this, can you put a bunch of condensers wired parallel until theere's enough capacitance it doesn't spark anymore? how many farads on average is a condenser? if i knew, i could get a bunch of capacitors from radio shack instead of shelling out for what a condenser costs.
  sparking at the pointsTopic by: Jon Dalton Jon Dalton 04/26/01 08:10PM
  Re: sparking at the pointsRe: Chris Robertson Chris Robertson 04/26/01 09:25PM
  Re: sparking at the pointsRe: mike mike 04/26/01 09:44PM
  Re: sparking at the pointsRe: Chris Robertson Chris Robertson 04/26/01 09:53PM
  Re: sparking at the pointsRe: Jon Dalton Jon Dalton 04/26/01 10:44PM
  Re: sparking at the pointsRe: Doug D. Doug D. 04/27/01 12:22AM
  Re: sparking at the pointsRe: Jon Dalton Jon Dalton 04/27/01 03:46PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 09:58AM
  pointing at the sparksRe: Fred Fred 04/27/01 02:39PM
  Re: pointing at the sparksRe: Jon Dalton Jon Dalton 04/27/01 03:13PM
  Re: sparking at the pointsRe: Rob Hoehn Rob Hoehn 04/27/01 04:48PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 07:24PM
  Re: sparking at the pointsRe: jimmiegimme jimmiegimme 04/27/01 07:38PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 07:44PM
  Re: sparking at the pointsRe: jimmiegimme jimmiegimme 04/27/01 07:57PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 04/27/01 08:01PM
  Re: sparking at the pointsRe: henry henry 05/17/01 01:52PM
  Re: sparking at the pointsRe: Ron Brown Ron Brown 05/17/01 02:19PM
