Re: new ped, first time out today
Lyman /
ok, so after taking the top of the carb off, i found that the clip was in the highest notch on the needle, so i moved it down two notches... there's still room to go one more if i need to. i also noticed that the choke slide as a pretty loose relationship with the pin it attatches to, so i think it's possible that it was not returning all the way, leaving it partially choked all the time... i fixed all that, started it up, and based on the short ride i took around the parking lot and revving it on the kickstand, it seems like it's a lot better, but everything is covered in snow and slush, so i'm unable to really test it out, and it looks like the weather is going to be shitty for at least a week. i hate NY
