Re: steering lock locked!
Ron Brown /
Dan,
There is a steel pin driven into the lock cylinder which fits into a slot in the housing. When you insert the key and turn it to the left you can either push it down to lock the forks, or pull it out if the clip is removed. The same steel pin keeps the lock in the down (locked) position when you turn the key to the right to remove it. Trying to remove the lock without first turning the cylinder/key all the way left will damage the lock.
If you have the same lock as I do and you can pull it out without first turning the key, you can also pull it out when the forks are locked.
Ron
  steering lock locked!Topic by: spartovi spartovi 04/24/01 04:34AM
  Re: steering lock locked!Re: Ron Brown Ron Brown 04/24/01 09:59AM
  Re: steering lock locked!Re: dan dan 04/24/01 12:06PM
  Re: steering lock locked!Re: Ron Brown Ron Brown 04/24/01 12:20PM
  Re: steering lock locked!Re: spartovi spartovi 04/24/01 01:02PM
  Re: steering lock locked!Re: Rob Hoehn Rob Hoehn 04/24/01 09:08PM
  Re: steering lock locked!Re: daveb daveb 04/25/01 02:06AM
  Re: steering lock locked!Re: Ron Brown Ron Brown 04/25/01 09:05AM
  Re: steering lock locked!Re: daveb daveb 04/25/01 11:08AM
  Re: steering lock locked!Re: Chris Robertson Chris Robertson 04/25/01 12:13PM
  Re: steering lock locked!Re: Ron Brown Ron Brown 04/25/01 03:55PM
