50 on 50 on a vespa...
anyone ever done 50 on 50 on a vespa?
Re: 50 on 50 on a vespa...
I think Graham is about to.
God speed!
i believe it's doable, for sure
i could see it happening. yeah.
i want to see it happen
I really doubt it.
I hope I am wrong, but unless you are willing to drop mad cash on it, I just don't think it could happen.
You would have to have one of the cases that give you the PHBG plus like a watercooled 50cc kit and the gears.
Hobbits are not easy to get 50/50 on. Hobbits and vespas are very similar, except hobbits are just better in almost all aspects except performance part selection.
I just really don't see it happening. I would be impressed if someone had a 45mph 50cc vespa.
Out of all the bikes I have tried to make fast, vespas are the hardest and most expensive. You can make them fast easily IF you have tons of money.
I am sure there are some 13 year olds in Europe who have 50/50 ciaos, but not round these parts.
i had 43mph on my 50cc bravo and i didn't even cut the crank or open up the intake. i didn't port anything other than the exhaust a little either.
it's totally doable, especially if you were using a 1 speed ciao.
man, debbie downer.
it's totally doable! do it john, don't doubt your ability...
Can't think of a more deserving quest
Has anybody done 50 on a 13mm carb regardless of make?
I think the only performance parts you would need to buy off the shelf are a pipe, a 13:13 carb if you wanna call that a peformance part, maybe a needle bearing crank, and if your variated a variator and maybe race gears.
the rest would all be done through port, crank, and piston mods. 13:13 carbs FTW!
you could totally do it on a 13/13. i would use a 1 speed ciao, you can gear them however you like. bigger front pulley and a tiny rear one, plus cut crank, opened intake, 13/13, good pipe, and some awesome porting and 50 is totally doable.
you're not going to have much low end, but that's not what we're talking about here, is it?
so dean, you dont think you can do it variated?
