PA50 1 or 2, wiki missing pics?
i know i have seen pics of pa50 I and II intakes and ramp plates next to each other for comparison, now i cant seem to find them. yes, i tried searching. i got a hobbit that was parts in a box, not sure what all i have. it's a yellow frame 1978, vin plate says paII. carb, marked BB on the flange, has a 78 jet (with what looks like a tip of a needle broken off in it). intake manifold looks tiny, has a 1 stamped on it. the case is marked PA50ME-J 113xxxx. the cylinder mounted on it is marked P2. PAII carb and jug with PAI case/variator? i need impact wrench to check out reedblock, havent looked under intake yet. i posted pics here, dont have them on this computer. http://www.mopedriders.org/viewtopic.php?t=12681
Re: PA50 1 or 2, wiki missing pics?
Downhill Harvey (OFMC) /
Want me to bring my pa50 I intake and reed block over to your place, for comparison.
I changed my PA50I to a PA50II so I have quite a bit of info on the the differences on this page.....
http://www.cardomain.com/ride/672833/9
harvey, you got an impact wrench? check your email for my address. david, thanks for pics link. so all i need is the ramp plate, not a whole variator and crank?
hey david, i have that same setup, put them light pa50 1 weights in there, it'll take off faster and still top out at 45 or so.
ohh yeah, watch out for using an impact on the flywheel nut, the crank strips easy.
Impact wrench? What do you need that for? Nate has one.
