E50 transmission fluid fill bolt size?
E50 transmission fluid fill bolt size, i need it. like m? and pitch. length is a plus, but not necessary.
thanks in advance!
jshay
Re: E50 transmission fluid fill bolt size?
One one ped I owned I didn't have the proper size and just tapped it to a size I can use.
I am 80% certain it is M8 (1.5mm pitch) at 10mm length.
I have them NOS . Puch E50 and Tomos use the same one.
Ike
ike, i attempted to use one of my tomos fills with no luck...hmmmm
Well, just to make sure, I just pulled the plug out of an old E50 and an old A35 and switched the plugs , no problem.
The only difference is, the Puch plugs are slotted for a screw driver and the Tomos plugs are not.
Maybe one of your engines has been retapped to a dfferent size or someone just forced an sae. screw in it.
Ike
