I took apart the carburator on my honda express 1980. I forgot how the screw goes in. It's the screw that is by the float. On the Expressly Mopeds webpage you can see a diagram of the carburator. I need to know if it goes on top or under the bar. I also need to know if it goes completely tight or what not. Thanks for any and all help. One more reason to say no to drugs......Memory Loss.
This is what happens to the engine. I can spray a little carb cleaner or even just poor a little gas into where the throttle cable goes in. It will run til it runs out of that gas. I'm not sure what the problem is.
