does anyone know how to fix a Vespa Bravo speedometer? It gets stuck at 20.
vespa speedometer
Re: vespa speedometer
They only go 20!
But seriously, folks....
You can CAREFULLY uncrimp the bezel to remove the lense. You should deform it equally around the circumference for the minimum amount to have it come off.
Take out the two screws at the bottom and the instrument will come out of the housing. Avoid touching that thin coil spring that returns the needle to zero.
I've lubricated mine with Bosch distributor grease after freeing it up and it's still going strong.
After you put the guts back in, CAREFULLY recrimp the bezel the best you can.
Jim
Rem
