Taking a littel off the top.... and bottom
I am trying to fit my 2.5 savas on the maxi, the sides of the swingarm are rubbing the tire just a little. Instead of buying that crappy ebr swingarm I thought I might try to dremmel or saw a little off the side give the tire some clearance. My question is... is this a stupid idea?
It looks like a lot of stresse would be placed on the sides of the swingarm, where i would be removing material, i dont want to die because of this...
Thanks for the help.
Re: Taking a littel off the top.... and bottom
the pink areas is where i would have to shave a little off....
if you do, be sure to reinforce it afterwards
shave the tires.
its cheaper and easier
I just pulled the tire back as far as i could and then rode around till it wore down a bit.
There was this great memory with Burt Munro in "The Fastest Indian" carving up them tires with a kitchen knife. thanks ring...
You can spread out the rear swing arm a bit.
the robot swing arm works just fine i have had mine for almost a year and there are no signs of ware, or breaking any where... oh and i'm about 215 lbs also.... anddd i got 2.5 gazzells to fit the stock swing arm also.... keep trying it will work..
