So I bought a box of 10 spark plugs on line, NGK B6HS, and when they showed up in the mail yesterday, I see that they have the larger terminal that's shaped like this.... http://www.neobrothers.co.uk/images/saab%20spark%20plug.jpg
while the spark plugs I need have a terminal like this.... http://raysbabyrays.mlblogs.com/spark%20plug.jpg
The terminal is the very top part that the wire on your moped sticks on, opposite of the end you screw into the engine, as I've just learned what the term is myself. I knew there were different kinds, but I assumed that a certain model would stick to one type of terminal, and if NGK was going to change the design of the plug, they could be nice enough to change the product number. Make them B6HS-A and B6HS-B or something like that.
Anyway, you guys ever run into this problem before? Is there a good place that you know sells a box of B6HS with the skinnier terminal? Or is it easier just to find a cap for the ignition coil that will let me use this whole box of spark plugs I just bought?
I see a whole list of boots and spark plug wires on treats, but I can't tell which one would fit this type of spark plug, and why there's a selection of 10 different ones, not to mention they all cost as much as just buying a new box of spark plugs anyway.
Any advice you guys have would be great!
Thanks
Josh
