will a Korado swingarm fit a magnum? since noone has a magnum swingarm to part with i found a korado frame and swingarm just wondering if it will fit.
Korado swingarm on a magnum
Re: Korado swingarm on a magnum
Hmm...considering that one mounts to the outside of a frame and the other inside I think not.
thx i just saw some pics. I may try to see if i can adapt it thru the pedal shaft like the korado.
i mounted an mb5 swing arm through the pedal shaft on a maxi... it took a good bit of work but yeah you can probably do it, your going to have to cut of the exhaust mount though soo.... think about that first....
