i got this 17mm bing carb off an old magnum, wanted to throw it on another bike i'm putting together. the needle looks really bad but its longer than a regular bing needle. just wondering if anyone knows what parts are interchangeable or specific to the 17mm carb. tanks mon.
17mm bing parts
Re: 17mm bing parts
i don't think anything on the top of the carb is interchangeable with the smaller bings. i was just messing with one recently and sizing it up with my 14 and the spring, needle and slide are all bigger. what does your intake look like? i think mine is a home made job, it holds the carb up at an angle. good luck!
Re: 17mm bing parts
i've got the curvy intake that i think came on the magum x
Re: 17mm bing parts
All the bottom parts (float, jets, etc) are the same, but the top parts (slide, needle, choke) are bigger than regular bing stuff.
Re: 17mm bing parts
Hey Kevin...Check with Rich (ragstrecher). There's a good chance he has what you need.
Re: 17mm bing parts
Hey Greer, I am pretty sure I have te same intake as you. It kind of has an S bend to it and it sits on a slant if you mount it on a puch cylinder, right?
If so, I think thats a magnum X intake. I am trying to figure out a way to mount it on a puch cylinder without that lean to it. I am thinking like a wedge shaped riser of some kind.
If anyone knows of a better way to do it, let me know.
But yeah, as far as getting a new needle, I would either try and find one similar or see if maybe treats or 77 could get one. They both have a pretty good selection of bing bits.
Re: 17mm bing parts
thanks buk i will do that, i really just need the needle and i'l be set
