Re: I GOT IT TO RUN!!!......but......
Chris Robertson /
Here's the stuff I'd recommend you check if your moped only runs with the choke on (in order I'd try them):
For information on procedure refer to the message "How To Fix Your Moped".
1. Make sure you have fresh gas (less than two or three months old),
2. Make sure your exhaust isn't plugged up. Have you cleaned it?
3. Make sure that the carburetor is on the engine tightly and has a good seal.
4. Clean the carburetor. Make sure to clean the jets very well.
5. Make sure there isn't any rust in your tank (make sure you have a fuel filter while you're at it --if you don't just buy a cheap in-line filter (about $2) at an auto parts store and hook it up between the fuel tank and the engine).
6. If you have a decompression valve on the cylinder head (somewhere near the spark plug), make sure it isn't loose or dirty.
7. Check the timing. Use the cigarette paper technique to set it.
8. Make sure you have good compression. This is best checked with a compression gauge --borrow or buy one. You want to have at least 100psi compression (some of my peds are at the 160psi mark) --the higher the better. If you have crappy compression, watch the engine while it's running for leaks.
May the Force be with you.
  spark but no spark?!?!Topic by: Matt Matt 04/09/01 12:34PM
  Re: spark but no spark?!?!Re: Brandon E Brandon E 04/09/01 01:21PM
  spark plugRe: Fred Fred 04/09/01 02:25PM
  Re: spark plugRe: Miguel Miguel 04/09/01 03:19PM
  Re: spark plugRe: Matt Matt 04/09/01 07:13PM
  Re: spark plugRe: Miguel Miguel 04/09/01 11:29PM
  Re: spark plugRe: Doug D Doug D 04/10/01 01:46AM
  Re: spark plugRe: daveb daveb 04/10/01 03:05AM
  Re: spark plugRe: Jon Dalton Jon Dalton 04/10/01 03:08AM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 08:47AM
  Re: spark but no spark?!?!Re: Doug D Doug D 04/10/01 09:43AM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 10:11AM
  Re: spark but no spark?!?!Re: Doug D Doug D 04/10/01 10:17AM
  Re: spark but no spark?!?!Re: Miguel Miguel 04/10/01 10:16AM
  Re: spark but no spark?!?!Re: Fred Fred 04/10/01 02:13PM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 05:01PM
  Re: spark but no spark?!?!Re: Fred Fred 04/10/01 10:17PM
  Re: spark but no spark?!?!Re: Matt Matt 04/11/01 12:09AM
  Re: spark but no spark?!?!Re: Fred Fred 04/11/01 12:22AM
  Re: spark but no spark?!?!Re: daveb daveb 04/11/01 01:35AM
  Re: spark but no spark?!?!Re: Matt Matt 04/11/01 10:10AM
  I GOT IT TO RUN!!!......but......Re: Matt Matt 04/11/01 11:34AM
  Re: I GOT IT TO RUN!!!......but......Re: Chris Robertson Chris Robertson 04/12/01 12:07PM
