Re: spark but no spark?!?!
Fred /
Well it is too late now... But you should have tested the 'new' coil before modifying it.
And it would have been far better to have re mounted it closer to the head (say.. on the front frame downtube).. then it was to cut and splice it.
Did you wrap it in insulating tape well enough?
And the part numbers out of a Honda book are not the same if it is a different length.
But now that you have done that... The next thing I would try (you may have already)...is to run a wire straight to the coil from the points.
Then I would try another coil/wire (borrow it maybe?) to eliminate your modified one as a problem.
Or perhaps take your coil off and try it on a running ped and see if it still runs.
  spark but no spark?!?!Topic by: Matt Matt 04/09/01 12:34PM
  Re: spark but no spark?!?!Re: Brandon E Brandon E 04/09/01 01:21PM
  spark plugRe: Fred Fred 04/09/01 02:25PM
  Re: spark plugRe: Miguel Miguel 04/09/01 03:19PM
  Re: spark plugRe: Matt Matt 04/09/01 07:13PM
  Re: spark plugRe: Miguel Miguel 04/09/01 11:29PM
  Re: spark plugRe: Doug D Doug D 04/10/01 01:46AM
  Re: spark plugRe: daveb daveb 04/10/01 03:05AM
  Re: spark plugRe: Jon Dalton Jon Dalton 04/10/01 03:08AM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 08:47AM
  Re: spark but no spark?!?!Re: Doug D Doug D 04/10/01 09:43AM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 10:11AM
  Re: spark but no spark?!?!Re: Doug D Doug D 04/10/01 10:17AM
  Re: spark but no spark?!?!Re: Miguel Miguel 04/10/01 10:16AM
  Re: spark but no spark?!?!Re: Fred Fred 04/10/01 02:13PM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 05:01PM
  Re: spark but no spark?!?!Re: Fred Fred 04/10/01 10:17PM
  Re: spark but no spark?!?!Re: Matt Matt 04/11/01 12:09AM
  Re: spark but no spark?!?!Re: Fred Fred 04/11/01 12:22AM
  Re: spark but no spark?!?!Re: daveb daveb 04/11/01 01:35AM
  Re: spark but no spark?!?!Re: Matt Matt 04/11/01 10:10AM
  I GOT IT TO RUN!!!......but......Re: Matt Matt 04/11/01 11:34AM
  Re: I GOT IT TO RUN!!!......but......Re: Chris Robertson Chris Robertson 04/12/01 12:07PM
