Re: spark but no spark?!?!
Fred /
Matt... the first thing I would do to get spark is to make sure the spark plug cap is not loose or broken.
By the way... where did your coil and wire and cap come from?... I remember you were going to substitute one from something else...that could be a problem.
If they are good... then I would first clean the points... because if there is ANY dirt.. even a speck... you will have no spark.
As far as starting...The PA50 has a cable operated compression release mechanism built into the cylinder head.. if it is leaking your ped will not start.
I have removed the pedals on mine and push start it with the release pulled in.. I have to push it about 5 feet...then release the comp. release lever.
  spark but no spark?!?!Topic by: Matt Matt 04/09/01 12:34PM
  Re: spark but no spark?!?!Re: Brandon E Brandon E 04/09/01 01:21PM
  spark plugRe: Fred Fred 04/09/01 02:25PM
  Re: spark plugRe: Miguel Miguel 04/09/01 03:19PM
  Re: spark plugRe: Matt Matt 04/09/01 07:13PM
  Re: spark plugRe: Miguel Miguel 04/09/01 11:29PM
  Re: spark plugRe: Doug D Doug D 04/10/01 01:46AM
  Re: spark plugRe: daveb daveb 04/10/01 03:05AM
  Re: spark plugRe: Jon Dalton Jon Dalton 04/10/01 03:08AM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 08:47AM
  Re: spark but no spark?!?!Re: Doug D Doug D 04/10/01 09:43AM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 10:11AM
  Re: spark but no spark?!?!Re: Doug D Doug D 04/10/01 10:17AM
  Re: spark but no spark?!?!Re: Miguel Miguel 04/10/01 10:16AM
  Re: spark but no spark?!?!Re: Fred Fred 04/10/01 02:13PM
  Re: spark but no spark?!?!Re: Matt Matt 04/10/01 05:01PM
  Re: spark but no spark?!?!Re: Fred Fred 04/10/01 10:17PM
  Re: spark but no spark?!?!Re: Matt Matt 04/11/01 12:09AM
  Re: spark but no spark?!?!Re: Fred Fred 04/11/01 12:22AM
  Re: spark but no spark?!?!Re: daveb daveb 04/11/01 01:35AM
  Re: spark but no spark?!?!Re: Matt Matt 04/11/01 10:10AM
  I GOT IT TO RUN!!!......but......Re: Matt Matt 04/11/01 11:34AM
  Re: I GOT IT TO RUN!!!......but......Re: Chris Robertson Chris Robertson 04/12/01 12:07PM
