Choke lever
How does the the choke work on a 96 Kinetic moped. It has a lever that you push down. How does it work? What's the procedure for the choke?
The Kidd
Re: Choke lever
My guess is you push the lever down.
Re: Choke lever
If it is anything like my 78 vespa you hold your tongue to the right, push the little lever down and when the motor starts the throttle opening will release the choke.
You will get used to it
Re: Choke lever
That's how it works. Thanks Mark. One more question. How do you know when the choke won't release besides the motor not running?
The Kidd
