Re: I need info for rebuilding 86 Spree
Scott /
I would try the red wire and the black wire together to make it run. I have a 85 Spree. Does yours have electric and kick start? Do you know you have to hold the rear brake to make electric start work? I tore part of my wiring apart trying to fix before someone told me that. The green wires should be ground wires. Give me a couple days and I will try to find out more. I'll either pull mine apart or go to the Honda dealer, I know him pretty good. If you can get to a dealer ask to see the shop manual with wiring diagram. Take along paper and pencil and write down what you need or better yet ask if dealer will make a copy for you.
  I need info for rebuilding 86 SpreeTopic by: Colin Colin 04/07/01 06:21PM
  Re: I need info for rebuilding 86 SpreeRe: Scott Scott 04/07/01 07:46PM
  Re: I need info for rebuilding 86 SpreeRe: Scott Scott 04/07/01 07:55PM
