Kinetic TFR
Rasta /
I recently did a complete tear down of the engine on my kinetic TFR. To start off the kinetic is a great bike once all its kinks and problems are worked out, which was also stated a little back on the from. One thing i learned about the engine is that if the lower part of the engine (crankcase) is working fine then do not attempt to take it apart. It is a pain in the ass, especially after u take the nuts off on the small side cause then the bolts fall back stick to the fan thingie(haha). Then you have to remove the fan thing and retrieve the bolt, but to remove the fan thing you need a special tool. Next tip i have is to use some high temp RTV silicon gasket maker around where the cylinder hits the crankase. Also remove the head gasket and put some of the gasket maker in between the cylinder and the cylinder head. I let this sit for 24 hours and the next day i put my engine back in and connected everything. I took it out for a ride and i noticed a pretty noticable difference when climbing hills, the ped use to almost stop on steep hills, now it would accelerate of keep the same speed up them. I don't know what it did in terms of top speed cause my spedomiter cable broke when the original owner crashed it. Another thing i did was somewhat polish my exhasut port, which really didn't need it. One last thing is if this all seems a little hard, its really not im only 14 and i did it by myself.
Ross R.
99 kinetic
  Kinetic TFRTopic by: Rasta Rasta 04/04/01 09:51PM
  Re: Kinetic TFRRe: Fred Fred 04/04/01 10:11PM
  Re: Kinetic TFRRe: Reeperette Reeperette 04/04/01 11:31PM
  Re: Kinetic TFRRe: Jim C. Jim C. 04/06/01 10:24PM
