Re: Engine cases paint or powdercoat
Sunset Paul /
Aren't Metrakits powder coated? They don't feel like regular paint.
"Some overhaul shops claim beneficial cooling effects of black paint on their engine. The theory is that black is a better emitter of infrared (heat) energy. A hot engine in a cold surrounding, radiates energy from the hot object to the cold. The amount of radiant cooling is (generally) dependent upon the temperature of the emitter (engine) and how efficient the engine is at radiating energy -- its emissivity. This derives from Kirchoff's Law where good absorbers are also good emitters. Since black is a good absorber of energy (that's why it's black) it's also a good emitter. A black object emits more radiant energy (cools faster) than a white or gold object that emits less radiant energy per unit of time. Painting an engine black increases the amount of radiant energy emitted by the hot engine to its colder surroundings and it will be cooler than a non-black engine."
First paragraph from here
