Kinetic..cheap, problems but okay
Vern /
Well, I finally got a moped shipped out here to the high plains. I bought the "low quality" Kinetic from India ($560 plus $125 to ship) I had parts broke in shipping but replacements were sent within a week. Cheap pedal broke on my first crank but I have steel ones from an old bike to replace them. After about the third ride, the air filter fell off but I have wedged a piece of foam between it and the frame. Otherwise, it seems to be running okay..(keeping fingers crossed) with just 50 miles ridden. I rode to the next town with the temperature at 34 degrees. Ran well but I froze my ass off. Get this, the manual calls for 4 percent Oil/gas mixture for first 300 miles.. then, 3 percent.. and the gas plug (not cap) says 2 percent? What is that.. take your pick between 2 or 3 percent? Then I have seen ads say "carry load, 250 lbs" ..the manual say "200, max"..but I have ridden son on back which is about 270 lbs load. It ran okay if you can get started! The Ads say: Top speed = 30+; the manual says 26. The manual was in 4 languages.. but lousy explanations with lousy illustrations in all four (my guess..I could only misunderstand the English). Well, if that engine doesn't have a fundamental problem.. it might work out to good value overall. I'm holding to 20 mph for the first 300 miles as one of the sheets said (another.. said 18.5!).
  Kinetic..cheap, problems but okayTopic by: Vern Vern 04/02/01 08:54PM
  Re: Kinetic..cheap, problems but okayRe: Reeperette Reeperette 04/03/01 07:01AM
  Re: Kinetic..cheap, problems but okayRe: Jim C. Jim C. 04/04/01 10:00PM
