I got a kitchen oven for my powdercoating shiz. I figure it would be a ton easier then using work lights. I stripped the oven down to where its gonna be laying on its back and I just need to build a longer box to put on top(another oven wont be long enough for a maxi frame) basically it will just be a metal frame with sheet metal screwed into it, and the door will slide in and out. then I have insulation from the oven and a ton of tin foil Ill put all over the top and hold all of it in place with chicken wire.
anyone have any easier ideas? suggestions for improvements on this design?
