1978 Vespa Bravo
What kind of top speed should I be getting out of this? I can't really find an answer, I am getting it to around 25mph. Thanks.
Re: 1978 Vespa Bravo
stock, probably 30ish. Your stock speedo isn't very accurate so you my be closer to 30 then you think. clean exhaust, carb, and make sure you don't have leaks.
there are three different versions. the 20mph, 25mph, and 30mph.
usually there is a sticker under the left side cover that will say. if not check the carb. 20 had a 12/9 carb, 25 had a 12/10, and 30 had a 12/12.
