Re: richer or leaner?
Ron Brown /
I'm with Fred, sounds too rich. Have you tried running without the air cleaner.\?
When I do a plug chop, I hit the kill switch or turn off the ignition before closing the throttle. The plug will get wet but will not change color. If you close the throttle from high speed to stop, the mixture will change a lot and may give you a false reading.
Ron
  sluggishTopic by: daveb daveb 03/29/01 11:47PM
  Re: sluggishRe: tim tim 03/30/01 12:08AM
  Re: sluggishRe: daveb daveb 03/30/01 12:43AM
  richer or leaner?Re: Fred Fred 03/30/01 08:13AM
  Re: richer or leaner?Re: Ron Brown Ron Brown 03/30/01 09:38AM
  Re: sluggishRe: david f martin david f martin 03/30/01 12:19AM
