Re: PUCH HAVING PROBLEMS NEED HELP
Eric Schuler /
Way to destroy my artwork STEVE_M ;) Just kidding. I suppose after all your tinkering you did clean the carb good and made sure u have no intake leaks anywhere correct? Also just for shit and giggles do a compression check to see if your rings are healthy. Will it idle with it off the kickstand? Does it run while on the stand and soon as its off it the engine dies? If so check your wiring box for loose connections. Also check your kill switch on your handle bars. If that doesent work....give it back to me for a day and ill nurse it back to health yet again for you :)
Trac Man
