'80 Concord stalls when throttle, cleaned carb.
I bought a 1980 Concord Shadow a week ago. It ran well at the time, but I could tell that there were some issues with the carb (Dellorto SHA 14.12) and the throttle cable was way too short and needed replaced. After I have cleaned everything, it stalls whenever I pull the throttle. The problem persists even after I have done the following: Cleaned gas varnish from carb (jet, float bowl, filter, etc.) Checked, then cleaned tank and petcock, which also had varnish. Cleaned The petcock leaked and needed replaced too. While I was at it I figured I
