Is it normal?
i just bought a moped carabela 78
and it works well, but well, when i fisrt start it it works awesome, but when i ride it and i stop the bike stops as well, and i have to pedali it in order to start the engine again.
why is this happening? any clue..
Re: Is it normal?
It sounds like it's having problems idling. Do you have a Dellorto carb on it? There's an idle screw you can turn (on pretty much any carb) to see if that helps, and if you do have a Dellorto, cleaning the idle passage should help too.
Re: Is it normal?
there is nothing normal in the world of mopeds
could be your carb or your clutch
Re: Is it normal?
Yeah, ditto on the idle adjustment. If it's super hard to get gowing after it shuts itself off, try a new spark plug. You may also need to change your main jet to a different size.
Re: Is it normal?
feather the throttle when you come to a stop.
