Don't do it!
To properly disassemble the engine, you must remove the flywheel, Remove the other side of the crankcase and everything behind it, then the small side.
But if your engine runs well, there's no reason to go into the lower end. There's nothing ther that needs attention. Put the bolts back in and let it be.
BTW, two strokes don't have valves.
Jim
