ATTN:Chris MWH
Chris, can you please check your email.
Thanks
Frank
Re: ATTN:Chris MWH
Frank for that email that you had sent 2 hours ago I have replied to it . Please allow some tome to answer emails.
Chris MWH
Re: ATTN:Chris MWH
Please don't use this forum as an email service. It clutters up the forum. You should have just called Chris or waited for a reply. Thanks. Swarm and Destroy!
Chris
Re: ATTN:Chris MWH
Your right, sorry!. I also did it to get a hold of Ike as well.
Sorry, wont happen again
Regards
Frank
Re: ATTN:Chris MWH
No problem. Keep posting!
Re: ATTN:Chris MWH
Cool!!
Thanks
Frank
Re: ATTN:Chris MWH
Yo Chris I hear you have some biturbos. I made the mistake of buying a used one, and I want to try a new one to see if it will make my revival faster. What kind of deal can you give me?
Re: ATTN:Chris MWH
Jon, I can set you up with a biturbo for a standard tomos but it will have to be modified slightly for use on the revival. A small bracket will have to be made for the rear mounting and you may have to slightly tweak the Header section so it will fit. I' will email you the price on it.
Chris
Re: ATTN:Chris MWH
Jon, Ike has the brackets. Your main problem will be the bend in the header pipe.
Re: ATTN:Chris MWH
Lenny. How much bend does it nee? I have not had the opportunity to put one on but was told it was only a slight bend.
Chris MWH
