I have a bottle of ZMAX for small engines and Im very hesitant about using it in my ped. Any suggesstions? Anyone try it with success? Pros, Cons?
Thank you,
Juna
Thank you,
Juna
I would not use that in my 'ped. Straight up, its got chemicals that attach to your cylinder walls. I would not use it if I were you, but maybe other people know something I dont.????
See what others have to say about it.
Frank
ive just made up my mind!! I just wont use it!
Thank you for the advise!
I used some in a weed eater. I saw no differince.
I used Zmax in my old Jawa, it did help. It most likely will not cause any problems if you use it. The stuff is supposed to attach to your cylinder walls, reducing friction. It's worth a shot if you have a well-used engine.
Ahhhh, the infamous "rebuild in a can" I get a good kick out of those late night infomercials. Stay away from gimmick products.
Chris MWH
