Re: Used tomos or questionable Jawa?
Robert Rosselit /
Don't worry about Jawa wiring. It's the most straight forward system I've seen yet. Jawa 207 engine uses the same bearings and seals as Puch (except for the rod bearings), The electronic ignition is maintenance free and you can build a replacement Thyristor for cheaper than you could buy points. The new Tomos would be a nicer bike in every respect but on the other hand, you can mod a puch intake and put a dellorto carb on that thing for a lot less than $1000.
