More TOMOS Information.
Was checkin through my notes while unpacking and found some old notes and such that might be useful to other Tomos owners, so here they are - I will just add what hasn't been put on the forum before, this time.
Additional Tomos Info.
Digits 5 and 6 of the VIN indicate model number.
42 = A3N Sprint
43 = A3N Sprint w/kickstart kit.
44 = A35 Targa
45 = A35 Targa
46 = A35 Targa TT LX
47 = A35 Targa
48 = A35 Targa TT LX w/kickstart kit.
49 = A35 Targa
56 = A35 Sprint TT
They probably also indicate points/CDI ignition type, but I don't have that info.
Horsepower 1.95hp @ 5200 RPM
Torque 3.5 Nm @ 3500 RPM
Fuel Mileage 6 pints/100 Miles
Ignition Advance for STOCK units.
Breaker Points = 1.5mm BTDC
CDI Electronic = 1.5mm BTDC
Breaker Gap 0.35mm-0.45mm
Brake drums are both 90mm Front and Rear.
Fuel Supply Petcock turns COUNTER CLOCKWISE for main tank, CLOCKWISE for reserve.
(so if yours is unmarked, now you'll know.)
Suggested cable lubricant is "Shell Retinax A or LX grease".
Suggested tire pressure-
FRONT= 21 PSI
REAR= 31 PSI
BULBS
Head lamp, 12V 25W/25W dual filament.
Rear light 12V 5W
Brake light 12V 10W
Turn Signal 12V 10W
Horn uses 12V 18W
And there are four complete electrical system diagrams in here, but I do not have a workin scanner right now, so that'll have to wait a bit.
This info should prove useful, however.
I still wish one of you guys would cobble alla this into a Tomos Faq - that would be very handy to have as a permanent link.
-T
Revival Wiring Diagram?
Brandon H. /
Anyone have a wiring diagram for the new Revival? I'd like to see how it differs from my Targa.
Keep the articles coming.
Dan Webber Kastner /
I just added it as an article. Go check it out, and if you ever want to edit it, or add to it email me.
dan
swarm
Serial Number for Revivals
Trike, good stuff!!! My Revival serial number is <br>
ZZ1A711292K068429 (without pedals).<br>That would make "71" the 5th and 6th digit. If other Revival owners could check their numbers maybe you could add it.<br>I can't wait to read dan's new article. Thanks Trike and dan.
Hey Dan ?
There's also the ton of stuff in the "Tomos Boatload" post.
If I could only get someone who's good at organizing to collate alla that mess into a Faq..
Guys ?
-T
Re: My revival serial number...
Here's my serial number:
ZZ1A711283K074829
Hey Jon, does yours have pedals?
Nope, no pedals. I'm going to post a pic of the wiring diagram later tho cuz somebody said they needed it. There are 2 versions tho? Full optional and standard... I don't know the difference. I think I have full optional.
Re: Revival Wiring Diagram?
Here ya go! Hope this helps
John Joedicke /
Great stuff, now does anyone have wiring diagram for a Targa LX. Thanks John
Jon,
Thanks for the diagram. Do you have any others?
No that's the only one I have sorry.
