Re: ciao electric problem
Fred /
OK... did you CLEAN the points?
If not... read the part about cleaning the points below in the post called "General Troubleshooting and Tune UP Guide".
Do that before you do anything else... a tiny bit of dirt in there will cause NO SPARK.
Next .... let me say that I believe that 90% of the time, somebody buys a coil and it doesn't fix the problem... because the coil wasn't bad.
If you have cleaned the points... then check all the wire connections between the points to the coil.
IF it still doesn't work, take the flywheel off and remove the condensor and test it or buy a new one... condensor.. $3... coil.. $25.
I can't tell you electrical test values for electrical components.. A book from the library will though.
  ciao electric problemTopic by: Gibson Hartwell Gibson Hartwell 03/22/01 01:57PM
  Re: ciao electric problemRe: Reeperette Reeperette 03/22/01 02:08PM
  Re: ciao electric problemRe: Fred Fred 03/22/01 04:31PM
  Re: ciao electric problemRe: Ron Brown Ron Brown 03/22/01 04:38PM
  Re: ciao electric problemRe: Jim C. Jim C. 03/22/01 11:33PM
  Re: ca electric problemRe: gimmejimmie gimmejimmie 03/23/01 10:58AM
  Re: ca electric problemRe: Gibson Hartwell Gibson Hartwell 03/25/01 10:07AM
  Re: ca electric problemRe: Jim C Jim C 03/26/01 09:54PM
  Re: ca electric problemRe: gimmejimmie gimmejimmie 03/26/01 10:08PM
  Re: ca electric problemRe: Jim C. Jim C. 03/28/01 12:10AM
