Was wondering if anyone can help a fellow moped rider in the great white north here eh?
I have a 1981 2 speed manuel jawa moped, that has a thryristor ignition unit....does anyone know how to test this little sucker with a multi meter?
thanks
thanks
If you get the info, i'd like to know also!
Hey Bob,
what is the problem with yours?
I can get a reading from the multi-meter when use the blue line(15) and common ground(frame), but when I attach the white wire to the coil(ground) from the "black box" I get no spark!! arrrgggg....
I don't know. I don't get a spark to start. Just finished building this Jawa, don't even know if my wires are right!
A motercycle shop might help you for free.
Ben Hunter
Hi fellow canuck,
I was going to buy a jawa a while ago and did some research on the net for them. found this site you might be interested in. www.jawacorner.com
its a Canadian site all about jawas. I hope they can help you guys out.
Good luck.
Ben
P.S. I live in burlington. we should go for a cruise when the weather gets nicer.
.....sounds like a good idea,Ben, I'm from Montreal, just a holler away from the green mountain state. Gotta get this Jawa running first. Let's see at 25MPH Ill probably get there in bout 4hrs!!!
Burlington Ontario, Sorry.
Ben
