Fred,
Now that you are into re-using copper gaskets, you may want to mention annealing. Heat the gasket to cherry red then dunk in cold water. You now have a clean, soft copper gasket which will seal much better. Works for exhaust washers and drain plug washers too, but only for copper.
Ron
