Yeh i was wondering if there are shift points on tomos targa s.On my 98 it feels like i have to red line it in first to get it to go in second . IF there are can you tell me where and how to adjust them
Any ideas aprecciated
Fox
Fox
Possible that maybe the 1st gear clutch is worn down? Mine '98 Tomos shifts at 15-20mph...seems like once I've been driving alot it wants to shift at 20mph.
Swarm and Destroy!
your clutch might be worn down,but i got a 80cc dirtbike and it's a 6 gear manual shift and i do the same thing to switch it, i let it rev up to where i think it needs to switch and i switch it. it might be fine though.
After a full tear-down and re-build, my Targa is doin exactly this, and it's factory-spec plus right now....and someone else just mentioned problems upshifting, my 1st suspicion is that the A5 is badly underpowered, but let me check a few more things, eh....like how it runs with 10w30 in it instead of ATF.
(it's in pieces all over the basement floor right now.)
-Ree
Its not that i have problems shifting it tis that it geets way to high rpms its like on a motorcycle before the engine blows in high rpms 1st gear its when it shifts into second
it is suposed to do that!!!!
