I believe they do, and if not..it surely isn't off by that much, you should be able to swap engines quite easily....it's the electricals that's the only pain in the arse with Tomos, I usually do a straight three wire rig on any conversion 'ped I've done in the past...Hot lead, Ignition, Ground-to-chassis, it's simpler that way.
-Ree
