Althought the Kinetic is a copy of the Vespa, it uses a head gasket and the cylinder base gasket is gasket material instead of aluminum as on the Vespa.
You must remove the engine to properly replace the cylinder base gasket. The gaskets are very cheap from Cosmopolitan Motors. Might as well order the nuts too.
Jim
