Re: motobecane piece of #$%*!
Ron Brown /
Joe,
When I left the last post, the forum was not displaying the text of posts, so I had no way of knowing it was a piece of #$%*! v50.
Anyway, it sounds like you have not really cleaned the carb well enough. See if you can determine if giving it short bursts of choke will keep it running. If so, you allmost certainly have not cleaned out the main jet enough. You may also have a fuel filter in the carb inlet, make sure you get good gas flow into the carb by testing flow with the top off.
You also should figure out why the throttle is sticky and fix it.
Ron
  motobecane piece of #$%*!Topic by: Joe Kott Joe Kott 03/15/01 02:09PM
  Re:Re: Ron Brown Ron Brown 03/15/01 02:22PM
  Re: motobecane piece of #$%*!Re: Ron Brown Ron Brown 03/15/01 06:51PM
  Re: motobecane piece of #$%*!Re: daveb daveb 03/16/01 09:12PM
  Re: motobecane piece of #$%*!Re: Ron Brown Ron Brown 03/17/01 10:54AM
  Re: motobecane piece of #$%*!Re: daveb daveb 03/18/01 10:23AM
