the ped ran last wk. can't get started. getting gas to the carb, the bowl fills. igot great spark.i 've cleaned the carb several times. So i put differ carbs on .NO GO
thanz dan
thanz dan
the problem might be compression because i've had the same problem with my 80cc dirtbike and i didn't know what was wrong with it until i took the front end and piston off and i found that the piston was all scratched up on the exhaust port side and the rings were stuck to the piston so i wasn't getting good compression, so take ur head off ur ped and check out ur piston and see if it's scratched up.
