Re: Eureka! WooHoo!
Ron Brown /
Dave,
Congratulations! It is "only an engine", after all.
Just to enlighten the rest of us, do you have any idea how many miles it took for your exhaust port to plug up so bad?
On your scored piston, if the rings are still a good fit in the grooves, the cylinder bore is still good and the piston not too loose, just ride it. From the performance you describe, it does not sound like you need a major top end rebuild.
Many 2 cycles have scored pistons from siezing up but all you need do is file off the high (shiny) spots and clear any burrs from the ring grooves. Use a file as abrasive paper leaves grains of abrasive embedded in the aluminum piston, doing bad things to the bore.
Don't get too many bugs in your teeth,
Ron
  Eureka! WooHoo!Topic by: david f martin david f martin 03/10/01 05:47PM
  Re: Eureka! WooHoo!Re: moby moby 03/10/01 07:35PM
  Re: Eureka! WooHoo!Re: Reeperette Reeperette 03/10/01 08:34PM
  Re: Eureka! WooHoo!Re: Ron Brown Ron Brown 03/11/01 10:36AM
  Re: Eureka! WooHoo!Re: david f martin david f martin 03/11/01 12:19PM
  Re: Eureka! WooHoo!Re: Ron Brown Ron Brown 03/11/01 01:09PM
