Re: Carb settings
Ray /
I'm unfamiliar with what you are talking about ( see, I told you carb settings were new to me :-) so I would have to say no.
The only settings I have touched are the set back screw where the cable comes
into the carb (to make sure it was not too loose or too tight), and the idle and mixture screws. I've set the idle down to where the bike is running nice and quiet, even with the BiTurbo. Next I turned the mixture screw one way till it started idling worse, then I turned it back the other way till it started idling worse. Then I twisted it back to the middle position where it was running the best, and re-adjusted the idle to get it back to quiet.
  Carb settingsTopic by: Ray Ray 03/09/01 11:17AM
  Re: Carb settingsRe: Alan Alan 03/09/01 01:01PM
  Re: Carb settingsRe: Ray Ray 03/09/01 01:24PM
  Re: Carb settingsRe: Ataristyle Ataristyle 03/09/01 03:11PM
  Re: Carb settings & PlugsRe: Ray Ray 03/09/01 03:32PM
  Carefull on the plugRe: Fred Fred 03/09/01 06:29PM
  Re: Carefull on the plugRe: Ron Brown Ron Brown 03/10/01 09:06AM
  Re: Careful on the plugRe: Fred Fred 03/10/01 12:53PM
  Re: Careful on the plugRe: Ron Brown Ron Brown 03/11/01 10:17AM
  Re: Carefull on the plugRe: Ray Ray 03/10/01 09:32AM
  Re: Carefull on the plugRe: Fred Fred 03/10/01 03:20PM
  Re: Carefull on the plugRe: Ray Ray 03/10/01 05:38PM
  zoom zoomRe: Ray Ray 03/12/01 02:45PM
  Re: Carb settingsRe: Tom Tom 03/10/01 08:02PM
  Re: Carb settingsRe: Ray Ray 03/11/01 09:58AM
  Re: Carb settingsRe: Ron Brown Ron Brown 03/11/01 10:21AM
