Carefull on the plug
Fred /
A hotter plug is not a performance enhancer.
The heat range of the plug is based on how the engine is tuned... and it is very unlikely that you need a hotter plug once you start to modify a motor.
Modified motors usually need COOLER plugs... because the increased performance makes them run hotter... add a hot plug to that and you will have a hole in the top of your piston... (maybe).
Base the plug heat range strictly on what color your plug is while running wide open.
In other words... finish your break in... settle on your oil mix... run it good and hard for a half mile... stop on the spot.... and pull the spark plug... If it is a light brown (tan).... leave that plug in.
I would recommend leaving the stock plug heat range in and altering the main jet to suit... not the other way around.
  Carb settingsTopic by: Ray Ray 03/09/01 11:17AM
  Re: Carb settingsRe: Alan Alan 03/09/01 01:01PM
  Re: Carb settingsRe: Ray Ray 03/09/01 01:24PM
  Re: Carb settingsRe: Ataristyle Ataristyle 03/09/01 03:11PM
  Re: Carb settings & PlugsRe: Ray Ray 03/09/01 03:32PM
  Carefull on the plugRe: Fred Fred 03/09/01 06:29PM
  Re: Carefull on the plugRe: Ron Brown Ron Brown 03/10/01 09:06AM
  Re: Careful on the plugRe: Fred Fred 03/10/01 12:53PM
  Re: Careful on the plugRe: Ron Brown Ron Brown 03/11/01 10:17AM
  Re: Carefull on the plugRe: Ray Ray 03/10/01 09:32AM
  Re: Carefull on the plugRe: Fred Fred 03/10/01 03:20PM
  Re: Carefull on the plugRe: Ray Ray 03/10/01 05:38PM
  zoom zoomRe: Ray Ray 03/12/01 02:45PM
  Re: Carb settingsRe: Tom Tom 03/10/01 08:02PM
  Re: Carb settingsRe: Ray Ray 03/11/01 09:58AM
  Re: Carb settingsRe: Ron Brown Ron Brown 03/11/01 10:21AM
