How to take front sprocket off???
þλ†Я¡¢k §¡§ΩИ /
Ive got the nut off but cant get the sprocket loose.
What tool would you recommend??
Re: How to take front sprocket off???
What bike?
Impact wrench
þλ†Я¡¢k §¡§ΩИ /
Morini M01
Is it on a shaft like a minarelli? If it is, I just put an open ended wrench under the sprocket and hit it with a hammer until it pops off. I'm sure there is a 'right' way to do it, but thats how I do it.
þλ†Я¡¢k §¡§ΩИ /
I tried that..no dice
It's probably slightly fused. Just keep working it.
2 jaw puller works great if you can get it on there, did that once on a Minarelli sprocket that was stuck on.
þλ†Я¡¢k §¡§ΩИ /
I'll keep going at it I guess then..pretty much everything is stuck on this
motor. Just dont wanna end up harming the case.
I was thinking about one of those 3 jaw gear pullers but I cant see myself
using it other than for this.
