Re: Cuising the driveway
Miguel /
Brandon:
Yeah, I've made the silly ignition mistake many a time ...
On the oil thing, just use regular gasoline for cars and add about 2.6 to 2.8 ounces of two-stroke oil for every gallon. That's what most of us run. Best thing to do is to premix it in a gallon container (or more, but just multiply 2.6 by the number of gallons, of course). Mixing in the fule tank is a bit of a hassle, since you'd have to shake the moped around to get it mixed.
I usually just take my gas container to the gas station and fill up (I have a two gallon and two one gallon containers). Then get home and add the right ammount of oil. Hold the can and shake it w/ a few turns of the wrist, then put it into the gas tank.
The advantage of this is that you don't have to run your moped dry to then add more fuel. It's all premixed and ready to go. When I run out of the mixed gas at home (last time I top off my tank), I ride down and buy more gas and go home and premix. You can also use a small two-stroke container (after empty) to carry around a quart or so of ail. Since that's a quarter tank of gas, that's enough to get you home. It's a great thing for emergencies (either your own or someone else's).
  Update on my PuchTopic by: Brandon E Brandon E 03/05/01 11:45PM
  Re: Update on my PuchRe: Miguel Miguel 03/06/01 02:51AM
  Re: Update on my PuchRe: Ron Brown Ron Brown 03/06/01 10:46AM
  Re: Update on my PuchRe: Brandon E Brandon E 03/06/01 12:45PM
  Re: Update on my PuchRe: Ron Brown Ron Brown 03/06/01 01:39PM
  Re: Update on my PuchRe: daveb daveb 03/06/01 03:23PM
  Re: Update on my PuchRe: Ron Brown Ron Brown 03/06/01 03:36PM
  Cuising the drivewayRe: Brandon E Brandon E 03/06/01 11:44PM
  Re: Cuising the drivewayRe: Miguel Miguel 03/07/01 12:03AM
  Re: Cuising the drivewayRe: Ron Brown Ron Brown 03/07/01 09:55AM
  Re: Cuising the drivewayRe: Brandon E Brandon E 03/07/01 12:37PM
  Re: Cuising the drivewayRe: Ron Brown Ron Brown 03/07/01 12:58PM
  Re: Cuising the drivewayRe: Brandon E Brandon E 03/07/01 01:22PM
  Bowling for (no) dollars.Re: Fred Fred 03/07/01 06:34PM
  Re: Bowling for (no) dollars.Re: Brandon E Brandon E 03/07/01 06:51PM
  Re: Bowling for (no) dollars.Re: Fred Fred 03/07/01 07:12PM
  Re: Bowling for (no) dollars.Re: Brandon E Brandon E 03/07/01 07:31PM
  No Lead neededRe: Fred Fred 03/07/01 07:06PM
  Re: No Lead neededRe: Ron Brown Ron Brown 03/07/01 08:22PM
  Stee-rike!Re: Brandon E Brandon E 03/07/01 08:45PM
